Latest topics |
» My 96 wagon
 Mon May 15, 2023 6:13 am by emmet.harten3
» E10 corolla wagon / estate wind deflectors wanted
 Mon May 15, 2023 5:32 am by emmet.harten3
» wind deflectors for e10 estate / bz touring top spoiler
 Mon May 15, 2023 5:30 am by emmet.harten3
» genuine oem moulded Mud flaps
 Mon May 15, 2023 5:29 am by emmet.harten3
» Wanted gxi/20v front bumper for e10 corolla
 Sat Feb 11, 2023 2:08 am by emmet.harten3
» AE101 arm rest
 Sat Feb 11, 2023 1:30 am by emmet.harten3
» Marvin the ZZE122 Wagon
 Sun Feb 05, 2023 1:53 pm by gold94corolla
» 7AGE Blacktop
 Fri Jan 20, 2023 1:49 pm by gold94corolla
» RARE JDM OEM PARTS
 Thu Dec 29, 2022 7:47 am by prnguy
» Te1 jumper to E1 wont flash codes
 Sun Sep 04, 2022 1:44 pm by kaitaiya
» AE101 Crotch Vent Install
 Sat Sep 03, 2022 12:36 pm by gold94corolla
» Ae 100 1993 Windscreen issue
 Fri Jul 22, 2022 3:15 pm by Yunmiliautoparts
» I'M FROM MALAYSIA. HELLO COROLLA AE101/AE111 WORLDWIDE LOVERS!
 Fri Jul 22, 2022 3:12 pm by Yunmiliautoparts
» My Supercharged TOM's Levin - Updated
 Sat Jun 25, 2022 11:23 pm by Batezy11
» 93-97 corolla optional extras & OEM Features
 Sat Jun 25, 2022 1:51 pm by Hyakuni102L
Who is online? |
In total there are 6 users online :: 0 Registered, 0 Hidden and 6 Guests :: 1 Bot
Top posting users this month |
Statistics |
Please Donate to the Site |
June 2023 |
Mon |
Tue |
Wed |
Thu |
Fri |
Sat |
Sun |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
11 |
12 |
13 |
14 |
15 |
16 |
17 |
18 |
19 |
20 |
21 |
22 |
23 |
24 |
25 |
26 |
27 |
28 |
29 |
30 |
Calendar |
DIY: How to Remove Trunk Taillight Panel
Subject: DIY: How to Remove Trunk Taillight Panel Fri Feb 17, 2012 7:32 am |
Remove the trunk liner on the inside of the trunk lid. To do this, remove all of the plastic compression screws holding the liner to the lid. (The trick is to hold the outer part while unscrewing the center to break it loose, then use the panel tool to pop it out)
To remove the Taillight panel, use an extended 10mm socket to remove the 4 nuts inside the trunk lid. One is in a hole (extended socket needed) and the other is parallel above it.
DO NOT remove the 2 nuts beside the lock.
Once the 4 bolts are removed, the light panel should pop out with a bit of force.
Needs Editing
I havn't actually successfully removed it yet. I was taking the last 10mm bolt off and it felt like the beebing screw broke in the taillight panel housing (the nut just keeps spinning instead of breaking loose). Very Frustrating because even with the 3 10mm nuts removed, it doesnt feel like it wants to come off. Im going to get out the rotary tool and see if I can cut the stupid thing off (but probably wont be able to get under the nut to cut it) arghhhhhhhhhhhhh lol
Am I missing anything?
Subject: Re: DIY: How to Remove Trunk Taillight Panel Fri Feb 17, 2012 8:49 am |
i want that liner! i dont have one
Subject: Re: DIY: How to Remove Trunk Taillight Panel Fri Feb 17, 2012 9:11 am |
lol You cant have it. Its in perfect condition. I even have all of the original screws for it lol
Subject: Re: DIY: How to Remove Trunk Taillight Panel Fri Feb 17, 2012 9:13 am |
Subject: Re: DIY: How to Remove Trunk Taillight Panel Fri Feb 17, 2012 10:07 am |
Sorry buddy lol
I think I found out why the panel is still tight. I found 2 white plastic pop in screws which might be holding the panel to the trunk.
They are located where the 2 red arrows are. The blue arrow is pointing to the bolt that broke on me. Im going to see if I can cut it tomorrow when I have more light.
Subject: Re: DIY: How to Remove Trunk Taillight Panel Fri Feb 17, 2012 11:19 am |
A better pic of the little white clip which I suspect is holding the panel. I am trying to think of a way to remove this without breaking it lol
Subject: Re: DIY: How to Remove Trunk Taillight Panel  |
Permissions in this forum: |
You cannot reply to topics in this forum
