JDM HVAC
Subject: Re: JDM HVAC Thu Nov 03, 2011 9:22 am |
wow good luck with tht bro
Subject: Re: JDM HVAC Fri Nov 04, 2011 12:42 am |
Thanks! I know I can do it, I just need the parts to do it...
Subject: Re: JDM HVAC Fri Nov 04, 2011 5:27 am |
Did this panel come in LHD? I thought it would have been cool to have on my LHD. I never saw a pic of the back before, nice.
Subject: Re: JDM HVAC Fri Nov 04, 2011 6:53 am |
No just RHD afaik... however with some polyester skills... I might be able to pull off a switch
Subject: Re: JDM HVAC Fri Nov 04, 2011 6:56 am |
it maybe alittle hard to do but good luck, iirc the surrounds are angled abit
Subject: Re: JDM HVAC Fri Nov 04, 2011 7:00 am |
I know it's gonna be hard... however since I want it that badly... I think I will prevail
Subject: Re: JDM HVAC Fri Nov 04, 2011 7:02 am |
Subject: Re: JDM HVAC Fri Nov 04, 2011 7:06 am |
However... still need to obtain the parts first... no change there unfortunately ;(
Subject: Re: JDM HVAC Fri Nov 04, 2011 1:22 pm |
Well keep in mind that you will have a lot of work to do if you are converting from the manual slider controls. The old system uses lots of metal pulls and cables to adjust the airflow and temperature. Only the fan speed is electric. So, if you install this all-electric control panel, you will need to convert over all the control systems as well controlling the airflow direction and the temperature and the inside/outside air circulation.
Subject: Re: JDM HVAC Fri Nov 04, 2011 6:29 pm |
I know it's gonna be alot of work, however when (not if) I succeed.... That would be a happy day
Subject: Re: JDM HVAC Fri Nov 04, 2011 6:30 pm |
Best is if someone finds a car in the junkyard with all the parts  I mean I can remove my dashboard to work underneath, I think I can manage in a day or two
Subject: Re: JDM HVAC Sat Nov 05, 2011 1:38 am |
yeah, that's what I mean, you'll need a lot more than just the panel, you'd need the entire car intact so that you can make sure to swap it all over. Even the air handler unit will need to be swapped.
Subject: Re: JDM HVAC Sat Nov 05, 2011 2:07 am |
Yep, that's the plan... however something might come in between... 'cause the bumper lips are now being sold... all in a sudden...
Subject: Re: JDM HVAC Sun Nov 06, 2011 12:02 pm |
I can get you one of those no sweat, but I really do hope you're aware of the work involved with fitting one. Chris (gold84) was bang on the money when he mentioned about changing everything over since the JDM HVAC has no slider controls. Everything is electric and the heater unit uses actuators to open and close the vents which direct air-flow (as opposed to a simple cable design like you've got now).
You'll also need the complete interior wiring loom for everything to work properly as there's a little sensor in the corner of the dashboard (will be a little blank currently in yours) which measures the temperature of the cabin. This is for the 'AUTO' function of the fan speed to work, as it heats or cools the temperature when it senses the cabin getting too hot or too cold. The shape is also a lot different between RHD and LHD, so you're in for a few major headaches. Anything is possible though, and I'm more than happy to send the parts over
Subject: Re: JDM HVAC Mon Nov 07, 2011 11:38 am |
That's gold 94 to you lol.
It is definitely a pain in the butt to do such a conversion. Now granted, what I did was way more involved, swapping over the interior and dash from another car, but part of the project was the HVAC controls. It is definitely a pain. At least I was able to use all the cable system, only slightly modified to work with the new controls.
Your interior will probably look like this at some point in the conversion (to give you an idea of the work)
And here's a closeup of the new HVAC controls when I was in the process of converting the cables and wiring harness.
Subject: Re: JDM HVAC Mon Nov 07, 2011 12:14 pm |
- gold94corolla wrote:
- That's gold94 to you lol.
Haha, whoops, typo
Subject: Re: JDM HVAC Mon Nov 07, 2011 8:40 pm |
Hehe, I know I will be in a world of pain, but it's worth it!  However, thanks for the offer, I will most definately be requiring the parts. However since I just bought something big, I need to save up a bit again  Once I have some saved up project money I will get back to you about this  For now... saving my ass off! I might be able to work some extra shifts in the pub to get some cash flowing. 'Cause I don't wanna borrow from my savings for the house...
Subject: Re: JDM HVAC  |
JDM HVAC
