Headlights Issues
XsV
Subject: Headlights Issues Fri Sep 19, 2014 5:27 pm |
So the headlights will come on but they are very dim and look as if they are pointed directly at the ground. The brights won't even come on either. Is there an adjustment screw that for whatever reason is off on both sides? I do know that the headlights don't look stock and the taillights are definitely not.
Subject: Re: Headlights Issues Sat Sep 20, 2014 11:11 am |
post pics of the head lights....
XsV
Subject: Re: Headlights Issues Sun Sep 21, 2014 10:01 am |
- gold94corolla wrote:
- post pics of the head lights....
So after some tinkering and research, I think these headlights are for a different model or non-US spec model. Everything just doesn't fit very well and the corners are held on by zip-ties. The headlights were also shoved into the rubber cover to hold them in place...  Some people...
From what I see, my headlights should have the high/low beams separate where as this one does not. How far off am I?
If so, looks like I just need new assemblies and I'll be good to go (and yes I know I need a new grille, suggestions?).
Here is the whole car:
Subject: Re: Headlights Issues Mon Sep 22, 2014 4:10 am |
cant seem to see the pictures
XsV
Subject: Re: Headlights Issues Mon Sep 22, 2014 4:57 am |
- miib14 wrote:
- cant seem to see the pictures
Sorry, I changed the host. Should be visible now.
Subject: Re: Headlights Issues Mon Sep 22, 2014 5:12 am |
yes they are the aftermarket / copies of the BZ Touring corolla headlights, there should also be corners with them, but looks like you have oem US corners.
They hold a h4 bulb (dual filament (hi/low in one bulb), ill try to find you the wiring diagram for it
They are adjustable, there should be a screw at the back of the headlight unit.
Subject: Re: Headlights Issues Mon Sep 22, 2014 5:19 am |
http://www.toyotanation.com/forum/130-7th-generation-1993-1997/67103-93-97-ae102-jdm-h4-headlight-wiring-diagram.html
Subject: Re: Headlights Issues Mon Sep 22, 2014 10:44 am |
Yep, just get the USA head lights again (you have several styles from which to choose) and it will all fit together again.
XsV
Subject: Re: Headlights Issues Mon Sep 22, 2014 10:53 am |
Ok perfect. The grille is USDM though right? I do need another grille as well.
Subject: Re: Headlights Issues Mon Sep 22, 2014 1:19 pm |
Yeah that one is US already, there are plenty of options on Ebay for you to replace it
XsV
Subject: Re: Headlights Issues Mon Sep 22, 2014 1:55 pm |
- Yeah that one is US already, there are plenty of options on Ebay for you to replace it
Ok, grille and assemblies ordered. Pics to come when they arrive!
Subject: Re: Headlights Issues Tue Sep 23, 2014 8:08 am |
Despite them looking almost identical in size, it's always best to get matching corners to suit the headlights (BZs bolt up slightly differently to US ones in my experience)
XsV
Subject: Re: Headlights Issues Wed Sep 24, 2014 8:37 am |
- Hiro wrote:
- Despite them looking almost identical in size, it's always best to get matching corners to suit the headlights (BZs bolt up slightly differently to US ones in my experience)
I did, I was worried about that. But thank you.
XsV
Subject: Re: Headlights Issues Sat Oct 11, 2014 2:54 am |
Ok here it is, new and improved.
Subject: Re: Headlights Issues Sat Oct 11, 2014 11:27 am |
Nice, everything fits! Any issues?
Subject: Re: Headlights Issues Sat Oct 11, 2014 8:42 pm |
I used to have those. Output was solid. Didn't have any complaints till I switched to the JDM ones.
XsV
Subject: Re: Headlights Issues Sun Oct 12, 2014 12:22 pm |
Yeah I think for the most part everything fits okay. The only thing that I am having issues with is that I want the corners and the main unit to be flush with each other (which they are now). But the lights themselves are slightly overlapping on the road and it bugs me. But when I center the light positions by turning the adjustment knobs, it moves the whole housing and then the assembly and the corners are no longer flush.
Looks like I'm stuck with choosing either form or function.
Other than that everything works fine and looks a helluva lot better.
Subject: Re: Headlights Issues Sun Oct 12, 2014 2:09 pm |
Yeah man, that's just how stock is, they never line up, due to how it aims. Stupid, but that's just how it is lol.
Subject: Re: Headlights Issues  |
Headlights Issues
